my grizz moves by itself!
Old Jan 23, 2006 | 04:36 PM
Kodiak660's Avatar
Default my grizz moves by itself!
Originally posted by: Grizzman42
omg, i cant beleive this. wat a stupid mistake! i just went itno my garage to check it out and my choke was not fully off. wow, wat a stupid thing to do, haha. well.... thnx for the help guys, but i have one more question..... i rode it with the choke on for bout 10 minutes kuz i had to get home and i didnt notice that it moved by itself untill i got onto my driveway. did i damagae anything by doing that?
As long as it starts and runs your ok.....only thing you would have done was foul your plug.
Old Jan 24, 2006 | 06:21 PM
Grizzman42's Avatar
ok welll...... i rode it today and everything seemed fine except for the choke. wen i put it on a little or half-way it worked fine but then wen i pulled it all the way it wouldnt work as well. i dont think its a problem but im just pointing it out.
Old Jan 24, 2006 | 06:46 PM
Kodiak660's Avatar
explain yourself better......when you pull it all the way do you mean all the way on? or off?
when you say not working as well do you mean your quad runs bad?....or wont keep running?
How cold is it where you are?
Old Jan 24, 2006 | 07:38 PM
Grizzman42's Avatar
ok here it goes...
u kno how wen u turn ur choke on ur engine runs faster and faster and faster. well today it was bout 35 degrees and i turned on the choke to warm up my quad. i noticed that wen i turned the choke alllllllllll the way on the engine would not run as fast as if i had the choke half or 3/4 on. it would work good except for wen i pulled it on all the way.
thnx for the help.
Old Jan 24, 2006 | 07:49 PM
  #15
Kodiak660's Avatar
ok here it goes...
thnx for the help.
Thats normal......you only need full choke to start......once mine is running I move the choke back to ½ so the fast idle will keep it running until its ready to go.
Old Jan 25, 2006 | 02:46 PM
  #16
hondabuster's Avatar
As outside temperatures move around, the place the choke offers an increase in idle speed will vary. On a warm day, if the choke is on full, the motor will be too rich, and choke and die.
In fact , thats one of the ways to check the chokes operation, to see if its working correctly.....warm day, warm motor, at idle,go full choke, the motor should die.
Just set the choke position where it offers the highest idle, or just start riding.
Old Jan 25, 2006 | 04:25 PM
  #17
Grizzman42's Avatar
o really? i never knew that. thnx guys. i thought the choke should always run fastest wen its all the way on. well, theres another thing i learned, lol.
lonerider856
Oct 13, 2023 03:45 PM
Dewhound
Apr 20, 2017 02:25 PM
Ahtatu
Sep 28, 2015 12:14 PM
1000gade
Sep 19, 2015 10:28 AM
toonces
Sep 5, 2015 01:14 PM
