Yamaha bear tracker elect. probs
Old Jan 28, 2006 | 01:41 AM
nattoy's Avatar
Default Yamaha bear tracker elect. probs
2000 bear tracker, the batter won't charge and when you turn on the head light it is extremely dim and gets dimmer when you rev it up. but if you put the light switch halfway between hi/low to where both are on, they get a little brighter. what do you think the problem is?
Old Jan 28, 2006 | 11:58 PM
TORK's Avatar
First check battery and charge system. If not charging check stator wiring . If stator is OK then regulator is most likly bad. Also check all your connections ( always do the easy and cheap things first ).
Ean
Dec 19, 2022 08:48 AM
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 5, 2015 05:55 PM
southbayman
Jul 24, 2015 09:30 AM
Peter_
Jul 18, 2015 07:06 AM
