04 Kodiak 450 front drive axle
Hey all!
I gotta right front drive axle problem. When jacked up the left front wheel spins free and smooth unlike the right side. It well for lack of a better way to explain it I guess it ratchets. Not free and smooth. It does this in neutral. Leading me to believe that its a cv-joint? 4x4 works fine and I don't notice any noise. Any ideas on how to trouble shoot this?
If you had a busted cv it would more than likely make noise in 4x4 or 2x4. becase it is always turning even if 4x4 is not engaged. Check and make sure that none of you boots are damaged. As far as the wheel turning goes it might just be the way the front diff is designed.
I have the same condition on the right front.. I thought it might be a wheel bearing? If it is the cv joint it may be a more serious problem. I haven't noticed any rips or tears in the cv boot. I do ride a considerable amount of mud and water. I had thought if it were a major deal I would have noticed a pull to the right, or something unusual, but everything seems fine. I plan to tear into the right front bearings this weekend and check them to see if they are worn, if not I will keep checking, maybe cv related.
Thanks for the reply's
Well you can't really tell that it's ratcheting unless the front wheel is off. I just finished installing front bearings,seals and upper & lower ball joints. It's all solid again like new. Still ratchets tho. I'm thinking its just how it is. Thanks for the feedback.
jayking232003
Dec 4, 2019 09:38 AM
hoopduerr
Jun 2, 2015 09:01 AM
