2006 Grizzly with a stalling at idle????? (Please Help)
Old Jul 16, 2006 | 09:35 PM
bansheecraze32's Avatar
Default 2006 Grizzly with a stalling at idle????? (Please Help)
I got a 2006 Yamaha Grizzly (All Stock) and at idle it will stall after about 10 sec even after it is warmed up. Also it has only 20 miles on it. I also will get a sputter at very low throttle. Is this a needle setting (Lean)????? If I put the choke on a tad it seems ok. Any Ideas?????
Old Jul 16, 2006 | 09:40 PM
squeege's Avatar
with all them toys listed you do know what a idle adjust **** is right? If so post more detailed info/what have you checked...[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jul 16, 2006 | 09:47 PM
Yes it's not a low idle problem I tried to bring it up a little no differnce. It sputters on light throttle and stall at idle after as little a 10 seconds. It seems lean because If I pull the choke a tad it runs better. I did clean the air Filter and it appears to be sealed.
Old Jul 16, 2006 | 10:29 PM
squeege's Avatar
prolly dirty carb.....my ttr 225 did the same thing.....
Old Jul 16, 2006 | 10:54 PM
This may sound strange, But I just fixed it. I took the air filter off and spray a little filter oil on the air filter and lowered the idle a tad and it idled. Took it for a spin in the yard no sputter and it's ok. Weird huh
Old Jul 16, 2006 | 11:21 PM
hondabuster's Avatar
Its posible the mixture screw (not the needle, that only comes into play at 1/8 throttle and more), may need a tweak richer. 1/8 to 1/4 turn out should be enough
Old Jul 16, 2006 | 11:24 PM
Is that the one with the metel cap over it?
Old Jul 16, 2006 | 11:25 PM
squeege's Avatar
yep the oil made it run a little rich for now.....hondabuster's on target[img]i/expressions/face-icon-small-tongue.gif[/img]
Old Jul 19, 2006 | 05:36 PM
imconstipated's Avatar
My 05 grizz did the same thing before the engine was broken in. Just give it time and it will not happen.
Old Aug 3, 2006 | 09:32 PM
imconstipated
I sent you a PM regarding the Mud Buster Cam
donintennessee
Aug 19, 2015 02:22 PM
momma's bike
Aug 6, 2015 09:49 AM
fire1998
Aug 6, 2015 02:46 AM
Roadglider09
1) Engine problems..
Jul 30, 2015 09:21 AM
hondarider1234
Jul 21, 2015 11:53 PM
