Arctic cat diesel atv
Old Jan 3, 2008 | 02:56 PM
  #21
TLC's Avatar
TLC
Default Arctic cat diesel atv
<div class="FTQUOTE"><begin quote>The diesel sound and smoke is what I like about diesels. they just have such great low end power . </end quote></div>
Because the Gasoline ATVs have a low range I do not see the diesels advantage even for hard work or pulling.
A diesel would be like having a gas motored ATV stuck in low range forever.
Old Jan 3, 2008 | 07:00 PM
  #22
HeftyLefty's Avatar
Diesels develop their max torque at lower rpms compared to a gasser. This allows them to last longer-less wear and tear-and pull/carry higher loads at lower rpms than a gasser, which can result in better fuel economy, depending on vehicle use.
Old Jan 5, 2008 | 04:31 PM
  #23
brpbear's Avatar
Before I rode it I would put a turbo on it. Their is no reason not to turbo it just look at pickups before the Dodge turbo
Old Jan 11, 2008 | 08:42 PM
  #24
ss454's Avatar
I bet that thing would have no trouble turning over some really big and agressive mud tires (outlaws). I'm curious if the mudders have taken a look into these?
Old Feb 24, 2009 | 10:32 AM
  #25
Xp's Avatar
Xp
I bought an AC diesel back in 07 few months after they come out. And it does have a **** load of torque. It pulled my 3/4ton diesel truck out of a mud hole once. I also put some 27x12x12 mud bitches on it. It does alright in the mud but if it ever hits bottom you better have a couple wheelers with you to pull it out. The only bad part about muding with it is where they put the battery and where it gets air to the airfilter they are are the back and kinda low so you cant go through to deep of mudd or water.
Old Feb 24, 2009 | 01:30 PM
  #26
Turfguy's Avatar
How much does it smoke when you get on it. I think that would be the coolest quality.
Old Feb 28, 2009 | 10:51 PM
  #27
Xp's Avatar
Xp
Unfortunately it don't smoke really at all a little puff when you crank it but that's bout it. I'm trying to figure out how to snorkel it anyone done it? I've googled it a lot but can't find anything on snorkeling the diesels.
Old Mar 1, 2009 | 02:16 PM
  #28
brpbear's Avatar
If it were trubo and had the pump set how would it run.
Old Jun 20, 2009 | 12:24 PM
  #29
Beaverwrangler's Avatar
Just remove the front rack, front plastics, and then the
stock air intake, which is just above the radiator.
Once the stock air box is removed you are left with two 2"
rubber boots coming out from under your handlebar/pod
area, just grab some metal strappy pipe clamp thingys shove
in a pvc or abs elbow, cut a couple holes in the black plastic
pieces that run under your front rack for them to come up
through and your done.
Not the best quad for running deep water, but for some
insurance for those times the puddle turns out deeper than
it looked it's a good idea to snork the air intake, plus diesels
don't need to be rejetted or anything so easier breathing is
an all around positive thing...
Old Jun 20, 2009 | 12:29 PM
  #30
Air intake is on top of the radiator at the front...
the rear snorkel is actually just the exhaust for
transmission cooling fan...
Customer Service #1
May 15, 2020 08:46 AM
TXMinuteman
Oct 6, 2015 06:43 AM
brad patnoe
Sep 23, 2015 06:44 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
Sep 1, 2015 01:45 AM
