Warn winch
Old Jan 21, 2008 | 12:06 AM
VooDoo01's Avatar
Default Warn winch
Hey Jeffin......do you know if the headlight pod you have on your atv is available for the Rancher. Doesn't it house a third headlight? I'd like to add that to my Rancher if possible.
Old Jan 21, 2008 | 12:20 AM
JeffinTD's Avatar
Default Warn winch
It isn't really "available" for the Rincon officially. One of the guys over at rinconriders figured out how to do it with adapted Foreman parts.
On the 650's there's some tabs on the meter bracket that have to get cut off and rewelded. On the 680's things generally bolt up, more or less.
I think it would be a cool mod on a Rancher, but I don't know of anyone who has looked into it to see if it could be done.
I like having a headlight that swings with the bar and also it doesn't get plastered with mud as easily as the lower headlights. Mostly I like the look, and that it makes my rinny a little different.
If you do a Rancher, take some photos and do us an article.
Old Jan 21, 2008 | 12:47 AM
VooDoo01's Avatar
Default Warn winch
I'll check into it. Do you know where I can order the pod? Where did you get yours from?
Old Jan 21, 2008 | 12:45 PM
JeffinTD's Avatar
Default Warn winch
There's a thread at rinconriders that shows how, and a member there, BKR, who supplied parts at a discount.
He knows all the little parts that are required, the headlight adjustment screw, the spring that goes over it, the little bushings that go over the bracket for the headlight to ride on...
It's been a while, but I want to say camo parts ran $175ish? Then a few bucks at the auto parts store for a Cole-hearse O ring sealed toggle switch, a cole-hearse rubber boot to go over it, and a waterproof in-line fuse holder.
I haven't looked at the dash of a Rancher to see if it is possible, or if it would be more complicated.
Old Jan 21, 2008 | 02:08 PM
  #15
VooDoo01's Avatar
Default Warn winch
Great, thanks for the info. I'll start looking around tonight. If I get it to work I'll post some pics for you. Thanks again.
Old Jan 21, 2008 | 02:15 PM
  #16
VooDoo01's Avatar
Default Warn winch
One last thing, do you know in which category the thread was written?
Old Jan 21, 2008 | 02:30 PM
  #17
JeffinTD's Avatar
Default Warn winch
There's a sticky at the top of the Modifications section.
Jeff Roper
Feb 1, 2022 11:48 AM
Johnny Mac
Aug 15, 2019 03:13 PM
panicmanic
Sep 28, 2015 12:59 PM
cboler9
Sep 24, 2015 08:35 PM
chewy78
Sep 8, 2015 10:37 AM
