Help! 99 grizzly 600 with no spark
99 Yamaha Grizzly 600
Had no spark. We changed the stator with one purchased from Ricky Stator. It ran fine about 4 hours while snow plowing and it died again. Again, no spark. We changed out the CDI box, ignition coil, new plug. We have a Yamaha service manual and checked everything, resistance on factory specs and also the ones for stator and pickup provided by Ricky Stator. Everything checks out fine. We cleaned the grounds and untaped the wiring harness and checked the ground crimps on the harness. We also did a point by point amp test by putting 2.5 amps through each wire to check for corrosion and broken strands. All that checked out fine. The source coil is putting out 91 volts. The pickup is fluctuating when cranking between 2 and 4 millivolts. I do not how many amps the source coil is actually putting out. I also put a inductive timing light around the feed wire to the ignition coil and when you are cranking it does not flash. But, when you let off it flashes once or maybe twice. Also if you crank it with the electric start, the timing light will flash once the battery is drawn down the point that it will barely crank. I have taken the kill switch apart and checked the contacts. I ohmed it and checked voltage. Also the main switch checks out fine. I'm out of ideas! Please help!
RticKwad
07-21-2015 03:00 PM
