Will this work to replace the switch on my Warn A2000?
Old Dec 12, 2011 | 09:10 AM
kodiakguy38's Avatar
Default Will this work to replace the switch on my Warn A2000?
I have a Warn A2000 on my 2000 Kodiak. I use the winch to raise and lower my snow plow among other things. With the Iowa winter closing in, I put the snow plow on my Kodiak only to find the winch wasn't working. I isolated the problem to the switch - the old DPDT rotary switch which I never cared for.
I'm looking to convert my A2000 to a rocker switch. I'm not terribly interested in the upgrade kit from Warn since it's over $100 and I don't really see the advantage.
From what I've read so far, it appears I need a contactor and a rocker switch to convert.
Would this cheap one off ebay work or would I regret it?
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
Would this be a better route to go?
http://www.amazon.com/KFI-Replacemen...3654478&sr=1-9
and
Amazon.com: WARN 64851 Replacement Mini Rocker Control Switch: Automotive
Just trying to find the best solution for replacing the crappy rotary switch that's broken.
Thanks in advance!!!
Old Dec 24, 2011 | 06:42 AM
Oldsman67330's Avatar
Does the warn rotary switch you have now go through a contactor or does it run from the switch direct to the winch motor? If it has a contactor, you can just put the rocker switch on it. If it does not have the contactor, I'd buy the kit you posted from ebay, it should work fine.
jayking232003
Dec 4, 2019 09:38 AM
txkevin
Sep 21, 2015 02:02 PM
jrooker6
Jun 17, 2015 12:28 PM
BEEFKING69
Jun 17, 2015 12:38 AM
ranvette
Jun 14, 2015 09:42 AM
