Atv advice for snow plowing
Old Sep 8, 2012 | 04:41 AM
Hedgehog's Avatar
Default Atv advice for snow plowing
Ive had atv's before that I plowed with but haven't had one in several years. With that said, I am looking for advice on purchasing a atv for plowing. I've always had Yamaha and Kawasaki and believe the Japanese brands are more reliable but I like the shift pattern on the Polaris. I need to be able to shift from low to reverse quickly because I will be in the road doing this. I will also hopefully get to use the atv for some trail riding. Any advice would be appreciated on atv models and plowing equipment. Thanks
Old Sep 8, 2012 | 06:57 AM
TLC's Avatar
TLC
Just make sure the ATV has True AWD not 3x4 and a low range. I like how Polaris can shift into reverse instantly without a complicated procedure like the rest do.
Old Sep 8, 2012 | 10:42 AM
Polaris Sportsman 500 is pretty bulletproof. The only brand I would avoid is Honda because it only has a limited slip front end. Been in more than a few situations where that little extra bit of traction helped.
Old Sep 8, 2012 | 09:30 PM
user493's Avatar
Moto Psycho
I've been plowing with Sportsman 500s for 15 years and they've never let me down.
Old Sep 9, 2012 | 08:01 PM
Hedgehog's Avatar
I found a 2005 Suzuki Vinson. It has a winch but don plow. How do you think this atv will do? The only downfall is its a straight rear axle, no efi and no locking front differential.
Old Sep 10, 2012 | 07:22 AM
TLC's Avatar
TLC
IRS is no advantage if the ATV is for plowing. You could put chains on the rear wheels to help. I have seen 2wd ATVs with chains plowing driveways and do pretty good.
Old Sep 10, 2012 | 02:41 PM
Hedgehog's Avatar
I know the IRS is no disadvantage for plowing, I just have never owned one with IRS and always said that my next one would have it.
Old Sep 12, 2012 | 11:01 PM
dwabbit's Avatar
I've been plowing with a 2003 Vinson the past 2 years. Works great.
ultangler
Nov 30, 2024 01:35 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
kodiacrunner
Oct 4, 2015 11:52 AM
wrencher82
Sep 28, 2015 10:02 PM
