Eiger Grille/Headlamp Gaurd
Old Dec 29, 2002 | 01:05 AM
ssauer40's Avatar
Default Eiger Grille/Headlamp Gaurd
Well, I have a picture of the finished grille gaurd in my gallery section for "ssauer40", and Eiger owners, check it out. I think you'll find this mod pretty "tight" [img]i/expressions/face-icon-small-wink.gif[/img]
Old May 7, 2004 | 10:49 PM
Eiger04's Avatar
Where did you get that guard at??? Thanks alot
Old May 7, 2004 | 11:52 PM
ssauer40's Avatar
The gaurd I made, it was from a piece of "expanded metal" as its called. I remove the entire front gaurd, cleaned off the pain on the inside, cut the metal to fit, shaped and welded it all to the original brush gaurd, then repainted it. It turned out real nice. Only drawback I found was driving at night, the glare from the mesh did reflect a little light back to me, thougn, visibilty was perfect in front (didnt impair the hedlamps at all). I solved that by just adding a box on the front. Problem solved![img]i/expressions/face-icon-small-wink.gif[/img]
Old May 10, 2004 | 09:04 PM
aksafari's Avatar
Nice. But why? I haven't noticed that anything can get at the headlights. I suppose if you were following someone that was kicking up rocks... but wouldn't that be dangerous to the rider?
Still, looks cool. Doesn't weigh much, either.
Old May 10, 2004 | 09:37 PM
ssauer40's Avatar
I didnt do it to protect me from rocks, its a utility quad afterall. I did it to protect everything from heavy brush, and yes, not much weight.
Old May 11, 2004 | 01:04 AM
aksafari's Avatar
you'd do well to put that stuff around your oil cooler if you actually go through brush thick enough to break your headlights
Old May 11, 2004 | 01:55 AM
ssauer40's Avatar
Problem solved, the oil cooler is behind the grille which is protected by the grille gaurd.
Old May 11, 2004 | 01:04 PM
MuddyEiger's Avatar
Looks pretty cool!
Old May 12, 2004 | 01:09 PM
aksafari's Avatar
Oil cooler isn't in danger from sticks coming through the grill, even without your gaurd, it's vulnerable to sticks coming up from underneath. That's the only thing I worry about going through the woods and over brush piles.
neilbedwell
Nov 10, 2018 11:02 AM
panicmanic
Dec 15, 2015 01:58 AM
baysport
Jul 23, 2015 11:37 AM
YamahaRaptor2002
Feb 14, 2002 09:45 PM
hillclimbing4kix
Nov 22, 2000 12:45 AM
