AM I SAFE?
Old May 17, 2003 | 02:14 AM
  #21
BIGQUADBOYINDALLAStx's Avatar
Default AM I SAFE?
im 14,, yea i think im safe ramping, it feels ok but it sound's like it is going to pop a shock or somthin.. freaked me out when i heard the noise..
Old May 17, 2003 | 10:41 AM
  #22
MBrooks420's Avatar
Default AM I SAFE?
Your probobly bottoming the suspension out. "popping" A shock is the least of the problems this can cause. You can tweak or break you frame if you do it to hard. If you are bottoming out you are clearly jumping it too high. You need to slow down or change the angle of your jump. That bike isn't built for jumping and continually doing so will probobly ruin it.
Old May 17, 2003 | 11:00 PM
  #23
snowbuster's Avatar
Default AM I SAFE?
snorkles stick about a foot above the quad so you can go deep. you cant submerge the air intake. engines cant breath water. they need air. as long as the top of the gas tank is out of the water makes no sence. the <u>air</u> intake needs to be above the water. hence the name, air intake. it cant intake water. quads arent ment to go off jumps ar go in the water unless you set it up to.
Old May 18, 2003 | 05:11 AM
  #24
MBrooks420's Avatar
Default AM I SAFE?
Trust me, I FULLY understand all of the principles on how an internal combustion engine works. I should have worded it so it could be understood by everyone. My intake is between the frame upper tube and the gas tank. It then runs up and between the steering stem and front off the gas tank. Therefore if my tank is above the water I'm fine.
Axl_Z
Mar 9, 2025 11:14 PM
Customer Service #1
May 15, 2020 08:46 AM
rgjackson
Sep 23, 2015 01:53 PM
carid
Sep 14, 2015 03:40 PM
toonces
Aug 13, 2015 01:48 PM
