Worst Stuck Photos Show us the gnarly mud! How deep can you go?
my deepest, but didn't get stuck
Old Nov 1, 2007 | 09:50 PM
  #21
RticKwad's Avatar
Runs Stealth!
Default my deepest, but didn't get stuck
Hebs,
Thanks for the info. Okay so the PICS above
in that type of situation you should run more air
right? For deep mudd'n in soupy swampy muskeg
marshy slop, should I have my PSI as inflated
as high as possible?
Thanks,
R'
Old Nov 1, 2007 | 09:51 PM
  #22
RticKwad's Avatar
Runs Stealth!
My 800 Sportsman is a heavy utility Quad like around 760 lbs plus my 350 lbs.
to boot!
R'
Old Nov 2, 2007 | 03:17 PM
  #23
Hebs's Avatar
That's basically a creek bed that he's driving thru. Air isn't really a factor as long as there's firm ground on the bottom. (unless he wants to do water wheelies or float with the help of basket ***** and such) I usually run about 6lbs in my tires. Not too low that the bead doesn't break easily... (had it happen before, what a day ruiner) And not too high that I lose traction. (I ride where I need the flex of the tire to grip) Some people run 8lbs up front and 6 in the rear for stability, (body roll) but those guys mostly ride trails... IMHO, you should be running between 6-7lbs on your PoPo when you're mudding...
Old Nov 4, 2007 | 09:12 AM
  #24
Brnxadk's Avatar
Wow, that's CRAZY !!!! LOL[img]i/expressions/face-icon-small-shocked.gif[/img]
Old Nov 4, 2007 | 09:56 AM
  #25
RticKwad's Avatar
Runs Stealth!
Thanks Hebs for the info. okay between 1 to 2 more PSI
in my tires. Okay got it!
Whats crazy Brnxadk?
R'
Old Nov 13, 2007 | 10:26 AM
  #26
Brnxadk's Avatar
Those pics r crazy!!
Old Nov 28, 2007 | 12:24 PM
  #27
RiverRanchBigBore's Avatar
those carlisles are radials. I used to run 20 to 25 in the front and 5 to 10 in the back. Hard tires are nasty in the mud. Keep the back a little lower because you want the back to drop and the front to come up and the back will grab nice.
Old Dec 3, 2007 | 08:28 AM
  #28
kickit755's Avatar
didnt get stuck eh.. sweet
Old Feb 26, 2008 | 10:16 PM
  #29
dvx 400 homie's Avatar
dang that's deep it's a good thing you had a snorkle
ReconBayou
Oct 31, 2022 05:37 PM
Jeff Roper
Feb 1, 2022 11:48 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
