4-POINT HARNESS SEAT BELTS
IT SEEMS TO ME THAT THE STOCK SEAT BELT that came with the rhino are not that safe. i see pictures of guys with the 4pt. system installed in there rhino.
1.how do you guys feel about the stock system?
2. will the after market 4pt. seat belts install without rhino modafication?
thanks
ant
thanks
ant
You need a "harness bar", which is a bar that bolts to the OEM rollbar and goes across behind the seats. That is what the top two points of the four point harness attach to. It is an easy to install and relatively cheap part. An aftermarket roll cage will already have a bar in this area for the added strength it provides, so when I say this I'm assuming you still have the stock cage. Both four point harnesses and five point harnesses provide much more safety than the stock seatbelts do. You can buy either style of harness, and you can also buy the fifth point strap and hardware separately if you get the four point and later decide you want a five point harness.
Jeff Roper
Feb 1, 2022 11:48 AM
