what size tires
I have a 660 rhino and it's time for some new shoes. I think I'm going with swamplites just unsure on size. I'm wanting to stay with my stock wheels,howdo youguys think 26's would handle with the stock wheels I figure I will have some baloon effect with the bigger tire. Thanks for any input. Jason
They should go on.. If the replacement tires are wider, you'll get some balloon effect. Also, the over all diameter (height) of the tire/wheel assy will probably increase. This will have some effect on overall gearing, low end snap. The adding of aftermarket wheels that are "heavier" than stock can also cause addl decrease in the low end snap/response. With the Rhino being pretty toady stock, it might be something to consider, then again if your just crawling around @ low speeds through trails/mud you probably won't see a real issue.. I put my stock tires on a set of (lighter) aluminum wheels (lighter than stock) and am totaly content with the performance, especially when compared to my buds Rhino's with altered tire & wheel setups... (flat Drags I pull away)
Rude Dog
Rude Dog
Hankey Pankey
May 1, 2018 01:33 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
