Yamaha Side by Sides Talk about the durable Yamaha Sport and Utility
Is there any power difference between an 05 and an 07?
Old May 26, 2008 | 09:01 PM
dirtyjohnny's Avatar
Default Is there any power difference between an 05 and an 07?
I own an 05 rhino and my cousin has an 07,mine is standard edition and his is limited. I have an intake clutch kit carb and a cdi box and still cant get past 43 mph. also it has no power off the line, his has only a cdi and takes off no prob what so ever,any thoughts?
Old Jun 2, 2008 | 11:48 AM
DesertViper's Avatar
There is no difference in performance between a stock '05 and a stock '07 Rhino. The aftermarket mods on your Rhino have decreased performance. Either your carb is not jetted correctly for the new intake, or you clutch kit is hurting power off the line and top speed. If you have larger tires than he does that will also hurt performance on a Rhino by a big margin. If your Rhino has significantly more miles on the engine that may be part of the problem as well. The OEM air filter on a Rhino is a poor excuse of an air filter because it doesn't seal well, and dirt can get around the filter. Rhino engines do not last very long anyway, and this is especially the case if dirt gets past the air filter, and your Rhino may be down on compression, and have less power because of that.
Bratman2
Aug 6, 2022 01:42 AM
Ronk407NY
Feb 13, 2016 11:05 AM
Gtsordo
Jul 22, 2015 01:27 PM
cornermike
Jul 8, 2015 11:44 PM
tweeder
Jul 5, 2015 01:57 PM
