Yamaha Side by Sides Talk about the durable Yamaha Sport and Utility
Digital Dash for Rhino
Old Sep 14, 2008 | 10:55 PM
RaptorOwner's Avatar
Default Digital Dash for Rhino
Do these have a fuel gauge built in? If so, what wire do you connect to for it to work from the sending unit?
Old Oct 4, 2008 | 03:43 PM
tripleR's Avatar
The 2006 Rhino does not have a fuel gage, but I am giving serious consideration to checking to see if they can retrofit one as it is next to impossible to tell how much fuel you have by looking at the tank.
Old Oct 6, 2008 | 03:46 PM
pwillie's Avatar
I just installed and after mkt gauge for the fuel tank,took about 3 hrs,but is is great.I also installed a digital dash gauge,and you need to change out your heat sender on th engine,cost around forty bucks.
Old Oct 21, 2008 | 08:31 AM
prowrench's Avatar
Yamaha added the fuel gauge on 2007 models. I installed one on my 06 model and its very straightforward, hardest part is drilling the hole into the top of the fuel tank. I also mounted matching engine temperature and voltage gauges.
I have read where some owners have mounted a light on the backside of the fuel tank, operated by a dash mounted switch. With the light on the fuel level is easily read through the sight gauge. A RED light works best. Simple & cheap way of getting it done.
Old Oct 21, 2008 | 09:05 AM
pwillie's Avatar
The cutting of the hole in the top of the tank,is easier if you use a sharp knife,and it leaves no residue.I have a lighted gauge,and it works well in the dark.
95wolv
Sep 27, 2024 12:00 PM
vandammages@gmail.com
Aug 20, 2020 11:50 AM
VABrute
Jan 6, 2016 07:39 PM
salixair
Nov 3, 2015 08:25 AM
greg74
Sep 10, 2015 07:58 AM
