Pros & cons for offset front wheels
Old May 30, 2003 | 05:50 PM
FsT4WrD's Avatar
Default Pros & cons for offset front wheels
On your Z you have spacers in the rear with paddles . The offfsets will even mine out perfect with the razr 2's on the rear . I was just wondering
if I put geckos (paddles) on the rear and leave the offsets on the front , the front will be about +2 or +3 wider . Would this be fine in the dunes
or should I put the stock rims and tires on for duning.
I am putting GBC shredders on the front offset red labels , the wife would nt let me get expensive tires and rims so I chose to get the better rim then tire.
Old May 30, 2003 | 05:54 PM
KGB's Avatar
KGB
I see. Yeah you will be a little wider up front, I rode hers like that for a while before I got the spacers and it was fine. It has a tendancy to push a little through the turns.I would run the wider front. It was noticible on hers and it was for a good reason. But then again they were mowhawks. I would still say to try the wider rims first and if it seems to steer weird than go back to stock.
Good Luck
Old May 30, 2003 | 05:56 PM
FsT4WrD's Avatar
Cool , thanks for the info
Old May 30, 2003 | 06:00 PM
JuJuBean's Avatar
I got a question and it may sound dumb as hell. How do u make a "thread" to talk in. Thanks
Old May 30, 2003 | 06:03 PM
  #15
FsT4WrD's Avatar
At the top you click on new topic , if thats what your talking about
Reactant
Mar 30, 2022 02:08 AM
Jul 21, 2015 03:03 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
rcappie4
Jul 18, 2015 07:51 AM
traumajunkie
Jul 7, 2015 09:22 AM
