YFZ450 - Kickstart kit from GYT-R!!!!!
#34
No it wasn't me. I haven't rode my 250R since I got back from Oregon Dunes in the middle of June. I wasn't at Pismo that weekend either. I was over there the 4th of July weekend and the weekend of AUG 1,2,&3 on my new YFZ450.
#35
if the yfz's battery setup is similar to most other quads you will need to get a w/b battery eliminator kit which acts as a regulator like the old battery did. when i removed my starter and bat. from my scrambler i just wired in a capacitor from radio shack and have not had any lighting trouble. if you do not hook anything up you will be running the risk of blowing bulbs at high rpm's.
#36
Man i dont know how accurate my scale is here but i slapped my battery on it and it showed alittle over 6 lbs and if the yfz starter motor weight's near what the rapter motor weight's it will be between 7-8 lbs im sure... i'll weight one at work monday and find out for sure
#37
how much is that7-10 lbs loss going to cost? Dry light or low carb beer, or beef up the performance and compensate for the weight! Of course i am over 250 so 10 pounds for a kick start would help as much as one less six pack!
Sep 23, 2015 06:23 AM
Mojave250A
Jul 11, 2015 10:38 AM
