Chian Lube?
Old Jun 10, 2003 | 07:41 AM
Y2JRaptor660R's Avatar
Default Chian Lube?
As i am sure you all know that chian lube that flicks up is a pain in the *** to get off. So does any company make lube that doesn't flick up but sticks on the chain where it does best?
Old Jun 10, 2003 | 08:01 AM
Predator03's Avatar
Default Chian Lube?
Sidewinder makes some good stuff, you can find it at their web site. I've also read some about Tri-Flow, it's teflon. I've never used it, but it sounds like it would work well. Also, make sure you don't spray it on a dirty chain, when people do that, that's when I notice it gob up so bad.
http://www.lickbike.com/i2827050.htm
http://www.sidewindersprockets.com/
Scott
Old Jun 10, 2003 | 10:07 AM
sixsixT's Avatar
Default Chian Lube?
Honda HP chain lube. I threw the other stuff in the garbage after trying it. I think it's a teflon like the others mentioned, I'll look at the can.
Old Jun 10, 2003 | 11:47 AM
RaptorRy's Avatar
Default Chian Lube?
I was told to use chain wax or tri-flow I use to use tri-flow on my BMX and it worked great
Old Jun 10, 2003 | 07:11 PM
GotRoost's Avatar
Default Chian Lube?
Yeah, Maxima chain wax was recommended to me. Sticks great and is great for O-ring chains as well.
bmark0610
Sep 7, 2015 09:42 PM
79hugger
Aug 30, 2015 02:21 PM
user493
Aug 13, 2015 12:54 PM
pete/ny
Feb 28, 2000 09:16 PM
wallsenterprises
10
Nov 29, 1999 11:57 PM
