stumble
Old Jun 19, 2003 | 07:49 PM
bigmark's Avatar
Default stumble
I was wondering if anyone could please help? I have a 2002 Warrior that stumbles or the engine bogs if you nail the throttle. This happens even after its warmed up. If you hit the throttle easy and then all the way its ok. Anyone have any ideas where to look first? Thanks[img]i/expressions/face-icon-small-sad.gif[/img]
Old Jun 19, 2003 | 08:14 PM
Diablo's Avatar
Default stumble
Sounds like carb issues to me. Did you ride through any water or mud last ride? Check your air filter, is it wet? This is a good starting point, could be a number of things. If you need to clean out the carb or do any adjustments, do a search through the forums under carb problems and you will find some info. Good luck
Old Jun 19, 2003 | 08:16 PM
ElectricShift's Avatar
Default stumble
Could be something as simple as the vent hose on the gas-tank being bent, or it could be a little bit more complicated, carb floats....etc.
Jmuddin284
Jan 19, 2026 07:16 AM
neilbedwell
Nov 10, 2018 11:02 AM
Jul 30, 2015 09:39 AM
derbyking
Aug 17, 2001 12:33 AM
JIGA
Oct 30, 2000 01:28 PM
