How do ya break-in a new cam and new rings at the same time ?
Old Jun 22, 2003 | 12:25 AM
FISHER1648's Avatar
Default How do ya break-in a new cam and new rings at the same time ?
Since the break-in procedure is differert for breaking in a cam VS. rings how do ya do it at the same time ? I've heard that to break-in a cam ya should run the motor at 3000 rpm without idleing for around 20 min. This is quite different than the new ring break-in - What gives ??
Old Jun 22, 2003 | 12:33 AM
ShadyRascal's Avatar
In all the car motors I've built with new cam/lifters and new pistons/rings I run them at 2500 or so for the first ten to fifteen minutes, and vary this rpm somewhat so it's not dead steady at any certain RPM. I would sure think an ATV motor would work the same way. After that initial run-in sans load then I let it cool down, then take an easy drive, feeding light throttle to get some load against the rings and again vary the rpm, nothing too high. Works for the cars at least. The cam is the thing you need to worry about most, it's easier to screw up than the rings.
Old Jun 22, 2003 | 01:12 AM
sixsixT's Avatar
Worry about the cam first.
Old Jun 22, 2003 | 01:59 AM
FastAndFurious's Avatar
The way to break it in is to ride fast fast fast and fast. race to get the cam warmed up and workin to its full potential. Peace muy grande
Old Jun 22, 2003 | 05:11 AM
UBETRUN's Avatar
Use lots of assembly lube and follow ShadyRascal's advice. Change the oil after the first couple of tanks of fuel and reach for the rev limiter:-)
Old Jun 22, 2003 | 06:30 PM
FISHER1648's Avatar
Thanks !
Old Jun 22, 2003 | 08:54 PM
RepTaR660r's Avatar
just ride the **** outta it, worked for me
Old Jun 22, 2003 | 11:18 PM
FISHER1648's Avatar
Whats the normal RPM range of a stock Warrior? I'm guessing 3000 RPM is 3/4 throttle (in neutral). Am I close ?
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
xbin87116
Jul 13, 2015 02:10 PM
clsharky
Jul 13, 2015 02:07 PM
