cams for warrior
Sounds like a good project ! I dont claim to be an expert but let me know if I can help - Here's one weird tool that really helped remove the inner cam bearing. I was at a loss until I found this thing. It may be a common tool for regular mechanics but being a novice I had never used a puller like this one.
Puller
Have fun and keep the little one busy with the project - if it's like my Warrior, it'll be around until he graduates High School [img]i/expressions/face-icon-small-happy.gif[/img]
Puller
If that bearing is like any other bearing on this wheeler then that puller would be nice. I am hoping that I can find a good machine shop to to my vavles and replaced the bearings for me at a good price but if not then I may buy one of those pullers.
Wat the heck is the CORE??? I am doing a rebuild on my warrior. I am putting verything brandnew in my head cept for valves wich are in grear condition. Dennis kirk is selling cams for the warrior so ya might want to give him a call i am planning on it. I am also going to check out at a big dealer this week.
About that puller, did u have to pull very hard our would a piece of wire or just a bent piece of mettal work? thanx man
#15
From the info I gathered, the Hot Cam does not have as much lift as the others - you can use stock valve springs. They claim more duration rather than lift.
The cam should just pull out of the head easily - screw the bolt that holds the cam gear back in and wiggle/pull on it. If you change the inner bearing you'll probably need some kind of puller.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
