03 griz, weight of primary clutch rollers
Youre gonna find that just changing the wieghts, isnt the most ideal...unless you change the secondary spring to balance it out. The back shifting is dependant on that spring/weight relationship. Thats why kits come with both the weights and secondary spring and usually new clutch springs which are stiffer than stock.
If you access to a lathe or know someone who does, its a simple thing to make, but with out a new secondary spring, you probably wont like the side effects.
I think EPI has good kits and one is on ebay now kit here
or here
or here
Steeldon
09-09-2015 09:38 AM
