first time owner question
Old Jul 17, 2003 | 12:05 PM
Hornishfan's Avatar
Default first time owner question
I just recently purchased a 1993 YFM350ERE. I noticed that when I was done riding that the lines going to the oil cooler where not warm at all, while the engine was, of course, hot. I drained the oil to check and clean the oil filter........that was fine. My question is, should I remove the oil cooler and attempt to blow air through it to see if it is plugged, and also is there a way to check to see if the oil pump is working correctly? Thanks.
Old Jul 17, 2003 | 05:57 PM
TheQuadSport230's Avatar
Not knowing what to say but replying to bump the postup to help you [img]i/expressions/face-icon-small-wink.gif[/img]
Old Jul 17, 2003 | 06:06 PM
HoundDog06's Avatar
Have you checked the oil filter to make sure its not plugged? If so...
Crack the line on the side of the oil cooler away from the pump. Start the bike and see if any oil is pumping through the cooler. If you get nothing, crack the line on the pump side. If you get oil then, the cooler is probably plugged. If not, you better pull the pump.
Let us know how it goes.
~HoundDog
Old Jul 17, 2003 | 08:39 PM
Hornishfan's Avatar
Thanks for the advice, I will try that. Thanks also to, TheQuadSport230, for bumping this up. As a new ATV owner, I look forward to learning from everyone on this site.
Old Jul 17, 2003 | 09:12 PM
RacinJason's Avatar
Wow a newbie that has a question before he broke something...sounds like someone who pays attention...you certainly want to make sure that you have good oil pres or that motor won't last to long
Old Jul 20, 2003 | 06:14 PM
Hornishfan's Avatar
Hounddog - I took the filter back out and blew air through the oil cooler inlet close to the filter. Oil (much dirtier) came out the outlet. It really didn't seem like it was bad enough to cause an obstruction, but when I re-assembled it....filled the oil, and ran it.......the lines are now hot. Thanks for the help all.
~Hornishfan
SOLOLUCKY
Oct 4, 2024 09:09 PM
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
DOAinNY
Jun 11, 2015 10:34 PM
ragewraps
May 27, 2015 08:07 AM
demonic650
Sep 19, 2001 05:25 PM
