Jet kits
Old Jul 31, 2003 | 12:12 AM
sixsixT's Avatar
Default Jet kits
What cam are you going to use?
Old Jul 31, 2003 | 12:14 AM
UBETRUN's Avatar
Default Jet kits
I ran 190/195 Mikuni jets and needles in a 12:1 with Hotcams Stage 2 at sea level. It ran very strong but I had a biatch of a time wth the floats and gave up on the stock carbs. The GYT-R needle is supposed to work with the Mikuni jets, the DJ needles and jets work together. Ernie660R is the first person I've heard successfully running a mix of DJ and Mikuni.
Old Jul 31, 2003 | 12:30 AM
HappaRap's Avatar
Lazy Boy Rider!
Default Jet kits
You should have all the information you need after these great posts. GYTR, enough said.
Old Jul 31, 2003 | 01:02 AM
BADBRONCO's Avatar
Default Jet kits
Good Luck finding the gytr Jet kit
Old Jul 31, 2003 | 02:00 AM
  #15
yamamayzf1000r's Avatar
Default Jet kits
I am still undecided.
I'll either go with Web Cams or HotCams, both of which are stage 1.
I don't want to change valve springs and valves just yet and I still want to retain some of the low end grunt for the tight trail riding.
Old Jul 31, 2003 | 10:41 AM
  #16
sixsixT's Avatar
Default Jet kits
Then you'll need to be around 190/195 like ubetrun said if you use the gyt-r kit.
Old Jul 31, 2003 | 04:14 PM
  #17
BigScary's Avatar
Default Jet kits
190/195?
I reallize there is a difference between dj and mikuni jets, but 190/195 just sounds big as hell.........
I am at sea level and I am only running 146/148?
what is the deaL?
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
Alex G.
Sep 16, 2015 12:13 PM
Lou Domenech
Sep 11, 2015 06:35 PM
Jaymc
Sep 11, 2015 07:45 AM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
