Thumb VS. Twist
Old Aug 16, 2003 | 10:07 PM
Entomber's Avatar
Default Thumb VS. Twist
Thumb all the way. Leaning in to turns and I think it's easier to let off on the gas with a thumb while still hanging on. Twist throttles you tend to hang on and inadvertedly give it gas. I saw a guy on a dirt bike run his up the tree that way in the woods. I rode a DS650 with a twist throttle, it was damn responsive.. but almost killed myself.
Old Aug 16, 2003 | 10:44 PM
TrailBreaker70's Avatar
The one on the Mojave I rode was set up more like a dirt bike. You had to twist it a long way to get it full throttle. It was really controllable, but that might also be because it wasn't that powerful.
Old Aug 16, 2003 | 11:50 PM
raptorblasterracer's Avatar
twist is great but on jumps and woops if u land hard u can slip ur wrist to the FULL THROTTLE POSITION i did it wile on a thumb ur thumb slips off the gass and u hold onto the grip....but riddin dirtbikes i have to say twist...blaster has twist and soon my yfz
Old Aug 17, 2003 | 12:15 AM
SpArX's Avatar
Yeah, I'm thumb, the only thing that makes twist better in my mind is for winter riding, you just have your hand that gets cold, not your hand and thumb.... So no need for a hand warmer, but I can see in turns and catwalks that the twist would make it awkward on my raptor, it's too finiky when your up that high, I can hold on just fine with my thumb.... I find you get better throttle adjustment control with the thumb for fine throttle control, you can hold just one side of the handle bar and gas it at the same time, like when your catwalking to give the thumbs up or whatever like that... Easier for tricks in the air on that side of the handlebars too....
Old Aug 17, 2003 | 12:26 AM
  #15
KamRider69's Avatar
Both work fine for me. If your thumb hurts then your a ***** or you just havent been riding enough and not use to it.The only time my thumb hurt was when I first went riding.Twist is simple after you ride a lil, you get use to the power.Doing wheelies seems easier but thats MO. And if you cant control it, thats too bad. I've never seen a motorcycle with a thumber on it.
Old Aug 17, 2003 | 01:00 AM
  #16
Entomber's Avatar
Not all thumb throttles are the same. The 400 EX is kind of stiff to push compared to a Stock DS, Raptor, Predator, KFX/Z. However Banshee's and a TM45 mm carb for the DS is the abosolute worst!!
mtdewmn
Jan 19, 2017 12:13 PM
89Lt250r
Sep 7, 2015 07:53 PM
neo27ny
Aug 24, 2015 02:02 AM
Jr Wagner
Aug 21, 2015 07:56 PM
Ashley S
Aug 6, 2015 12:56 PM
