blaster wont start
Old Aug 26, 2003 | 06:58 PM
rxfx's Avatar
Default blaster wont start
hey, im posting this for a friend, i kno nothing about quads! well, today we were riding and as we got to the end of a hill his blaster bogged out! we havent been able to start it since then and hadda tow it out wit his jeep and since then it hasnt started. i noticed a hose at the bottom of his carb was hanging down and we dont kno if its supposed to be there or not. there are two little hoses on the sides that look like they are for overflow and it just doesnt look like this one at the bottom of the carb should be there hanging like that. sometimes it will turn over, but wont idle..it struggles and we have the throttle pinned. it wont stay on for more then a couple seconds and sometimes it wont even turn over! can anyone help?
Old Aug 26, 2003 | 07:04 PM
rxfx's Avatar
think it could be the valve float?
Old Aug 26, 2003 | 07:39 PM
Cly's Avatar
Cly
I would try a new spark plug first.But when you have the plug out hold your finger over the spark plug hole and have someone kick it over to make sure you have compression.If the compression is ok go ahead and put in a new plug.
Cly
Old Aug 26, 2003 | 09:55 PM
rxfx's Avatar
o, there is compression...if there wasnt, it wouldnt run like it does... like, i can have it pinned and it would run for good 10 seconds. ill check the spark. what else can cause this?
Old Aug 26, 2003 | 10:38 PM
Cly's Avatar
Cly
I wouldn't just check the plug I would replace it......It could be the float in the carb sticking you can try and tap on the side of the float bowl with the blunt end of a screw driver or someting and see if it starts.
Cly
Old Aug 27, 2003 | 01:12 AM
rxfx's Avatar
ok, ill replace it. now, im not familiar with these types of carbs, where is the float bowl located?
Old Aug 27, 2003 | 02:10 AM
rabbit1's Avatar
if it is older than an 03 it possiable it might be the throttle sensor it is located under the front hood unplug it make sure you dont unplug the cdi ....seen alot of those go bad if you unplug it it should be fine if thats what it is ..or ck. the reeds ...or dirt in the carb....
Old Aug 27, 2003 | 02:14 AM
scrambler123's Avatar
i had a similar problem with mine it did the same thing that u stated so i took the carb apart and cleaned and it ran for a little while then died again then i did it all over again and the same thing happened. I ended up putting new reeds in it and that solved the problem.
Old Aug 27, 2003 | 02:18 AM
rabbit1's Avatar
i would ck the throttle sensor first its much easier to get to than the reed ....than go from there
Old Aug 27, 2003 | 12:05 PM
rxfx's Avatar
great, thanks for all the help, but one more question. what are reeds? never heard of them.
Shooterj2003
Jun 21, 2015 09:02 PM
1000gade
May 27, 2015 12:37 PM
B4NSH333
May 26, 2015 06:55 AM
littleatvr
May 18, 2000 07:45 PM
dunc_n
Aug 26, 1999 09:32 PM
