How to improve Raptor Stock Carbs?
Old Sep 7, 2003 | 06:24 PM
raptor03's Avatar
Default How to improve Raptor Stock Carbs?
My lips are sealed..but seriousley i can tell a big diffrence..
Old Sep 7, 2003 | 11:42 PM
LOWBOWTIE's Avatar
ttt
Old Sep 8, 2003 | 05:31 PM
ba01raptoraz's Avatar
So what would I get for $150 or $300? What do you guys do?
What is a pingle valve?
Thanks for the replies!
Old Sep 8, 2003 | 07:05 PM
Ward660R's Avatar
The pingle valve is a fuel valve that replaces the stock on/off/reserve switch on your tank.
See it here.
I switched carbs. However if you don't want the hassle I went through for the lectron and you don't want the steep price of FCRs there is absolutely NO better choice. And I haven't compared my set-up to a set of Craycraft modded carbs to see any differance, nor have I heard a comparrison of them to FCRs.
Old Sep 8, 2003 | 08:08 PM
  #15
Raptor03Rider's Avatar
replace those crappy float bowl screws..they suck and strip very easily...doesn't make you go any faster, but your job will be a whole lot easier next time you rejet...
Old Sep 8, 2003 | 08:38 PM
  #16
raptor03's Avatar
I will try the modded stock carbs first,then i am getting some lectrons and will hopefully have them buy FSw and i will let you know the diffrence..
Old Sep 8, 2003 | 10:15 PM
  #17
XtremeRaptor's Avatar
Does anybody know how long the turn-around time is on Craycraft modified stock carbs?
Old Sep 8, 2003 | 10:50 PM
  #18
sixsixT's Avatar
I think he has some modded ones in stock for exchange. He'd just need to know what mods your engine has to set them up. So it should be a real fast turn around.
Old Sep 8, 2003 | 10:55 PM
  #19
COOL!!!!!!!!!!!!!!!!!!! Thanks sixsixT!!!!!!!!!!!! I really appreciate it!!!!!!!!![img]i/expressions/face-icon-small-happy.gif[/img]
  #20
bvstone's Avatar
Jetting will depend on the mods you do to the airbox pipe.. but one good thing to do is clip 2 rings off the slide springs.. will improve throttle response.
I've tuned a few rappies and they are touchy.. even a couple small holes in the airbox will change your main jet a size or two, and possibly the needle clip position. But #3 is where most of em are (I tuned one with it on #4 just because it felt better and the airbox had a couple holes).
