Need new rod for High Comp piston?
I am about to take my Raptor engine to another level with upgrades by getting the head ported/polished, valve job, possibly bigger valves, & possibly slight overbore 12:1 piston (100.5mm or 101mm). My hesitation is over whether or not to use the 12:1 piston since some engine builders are advising to install a new Carillo rod if I use a 12:1 or higher compresion piston. Other engine builders don't think its necessary & one even uses a 13:1 with the stock rod. Some feel that the 686 bore(102mm) with 12:1 compression definitely requires the Carillo rod but if I stayed with a smaller bore I could still use the stock rod.
I would like to hear any/all opinions especially from those who run 12:1 or higher compression pistons with the stock rod & those who chose to use the Carillo rod either due to an engine failure or just felt it was a good insurance policy.
If you have the dough I would do it. Mine let go for whatever reason after putting together a 12:1 686. It's more of an insurance policy at this point. I wouldn't build one up again without a Carillo Rod. JMHO Many others prefer the stock rod for weight, but that can be offset in other areas.
The rod in my '02 twisted with just a 11:1 JE and Stage 1 HotCam!!!!!!!!!!!!![img]i/expressions/face-icon-small-mad.gif[/img] Now I have a Carrillo in it and I don't have any worries!!!!!!![img]i/expressions/face-icon-small-happy.gif[/img] If you can afford it, do it!!!!!!!!!!!!!!!
