changing sprockets on raptor
Old Sep 15, 2003 | 08:55 PM
blinddog's Avatar
Default changing sprockets on raptor
when you go to undo the nut on the drive sprocket there is that thing with the tab that holds the nut from turning.when you change the sprocket,are you supposed to bend it and re use it or buy another one?
same with the rear.it has the same kind of thing.those things to keep the nuts from turning.
Old Sep 15, 2003 | 10:20 PM
duneittilludie's Avatar
you can use the washer with the tabs on it again as long as it is not cracked.it is a good idea to have 1 extra for the front and the same for the back if you change your sprockets often because these washers do not last through too many changes.
Old Sep 16, 2003 | 12:22 AM
RaptorOwner's Avatar
Yes I got 4 changes out of mine before I replaced them. Thats all I could go cuz there were no tabs after I took them off for the 5th time. It all depends on how it looks like duneittilludie mentioned above.
Old Sep 16, 2003 | 12:26 AM
wshrdskin's Avatar
Same scenario here. Once the tabs start to crack replace them. Just replaced front and backs with my last sprocket change myself. Believe it or not my dealer (a honda dealer by name) had them in stock. [img]i/expressions/face-icon-small-smile.gif[/img] As well as the 14 tooth front sprocket I wanted to try. Ba lee dat. LOL
Old Sep 16, 2003 | 12:31 AM
Hossblur's Avatar
Make sure you bend them down tight, I have heard of guys not doing that and leaking out of the nut
Old Sep 17, 2003 | 01:17 AM
blinddog's Avatar
thanks guys.i changed the front sprocket to a 12 today and love it.
Bratman2
Aug 6, 2022 01:42 AM
oldschool64
Aug 12, 2015 07:13 AM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
