2002 Grizzly 660 engine braking- not right
I have a 2002 grizzly 660 w/ the following mods :
k&n filter
HMF header and pipe(loud)
port & polished head
webcam racing cam
Problem is, recently my engine braking has quit working unless the engine is above "normal" idle. I don't think the mods have anything to do with it as the engine braking worked great for many months after I made the changes. If i turn the idle up the engine braking works better but not like it should and these suckers get hot enough as it is.
Any insight would be helpful.
Mike
spradling@adelphia.net
k&n filter
webcam racing cam
Mike
Try checking the engine idle speed with a tach (1450 to 1550 RPM), and you must mic the belt to ensure it is sized to spec--( 1.31 inches new and 1.18 inches minimum). Also you may need to clean and regrease the pri and sec sheaves. Post back
RedRancher
Oct 15, 2020 01:45 PM
