atv problem
Old Oct 9, 2003 | 03:11 PM
jvc's Avatar
jvc
Default atv problem
I just bought a none running 2000 Yamaha Bear Tracker 230 and having problems getting it to run, I cleaned the carb and drained the old gas and refilled with new gas. I am getting a good spark and it smokes when trying to start it but it will not run even when you prime it, it back fires sometimes while cranking. I noticed one the screws on the timing cover was stripped out like someone had tried to take it apart or over tightened the screw so I got the screw out and looked at the chain which looks very clean but seems very tight, there were a few finger prints on the inside of the timing cover so I am thinking somone has messed with the timing or chain and that is why it won't run. My question is does anyone know how to time this bike? I think I figured out the mark on the cam and the head but want to make sure I am right and find out the best way to time the bike. Any help would great, I want to get it right the first time instead of messing something else up or having to do it multiple times.
Thanks,
Dan Worth
Old Oct 9, 2003 | 06:02 PM
Hozed's Avatar
Default atv problem
id call a yamaha dealer... they could probably tell ya.
Old Oct 9, 2003 | 06:03 PM
Raptorx44's Avatar
Default atv problem
I would buy a service manual before i touched anything.
Old Oct 9, 2003 | 06:26 PM
XxDumontRaptorxX's Avatar
Default atv problem
I agree get a service manual. Check correct jetting and needle placements as well, make sure no carb boots are leaking or off. I would replace the spark plug anyways, just to be sure. I don't have this quad so I can't help you much more than the obvious things.
Old Oct 11, 2003 | 12:53 PM
fordblaster's Avatar
Default atv problem
what happened on the last run the timing chain could have slipped open the valve cover and look under there i bet you problem is there.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
