havoline 10-40
Old Nov 8, 2003 | 12:31 PM
ElectricShift's Avatar
Default havoline 10-40
I put havoline 10-40 oil in my atv (grizzly 600) is this ok? Its running good...
Old Nov 8, 2003 | 01:39 PM
shastadog's Avatar
My owners manual gives the oil specs. I don't see it harming your engine.
Old Nov 8, 2003 | 01:46 PM
Raptoryfn660r's Avatar
RIP Dear Friend
Look at the back of the bottle and look for the circle about the size of a dime: API service
In the bottom half of that circle it should not say (energy conserving). Most 10w40 oils do not have this written in the lower half. The oils that do not have this written are OK to use.
Old Nov 9, 2003 | 01:59 AM
ArkansasTraveler's Avatar
Look for the oil to say for Wet Clutch Protection as well. I found the Havoline Motorcycle 4 Stroke 10w40 Wet Clutch Protection Oil at AutoZone for $2.99 and this will be fine in your Grizzly. The normal Auto Oil is not made for Wet Clutch from what I can tell so far. I would only use approved oils in my Yamaha's. Look in your manual to ensure what is appropriate for the Grizzly, but I am sure what I put in my Kodiak and Blaster will work. I did start with the Yamalube 10w30 4 Cycle Oil, but I don't like paying $4 a quart and having to travel 30 miles to the Yamaha dealer to get it. You should also change the Oil Filter often as well. I paid $12.99 at the dealer for the 1st one, but found cross reference to STP Oil Filter, looks almost identical, much better than the FRAM, for only $5.99 at AutoZone.
Its much cheeper to change you oil and filter than your engine [img]i/expressions/face-icon-small-smile.gif[/img]
Good Luck
NC Rebel
Sep 28, 2009 08:39 AM
FlatTire
Nov 3, 2002 08:23 PM
MagnumMudMan
May 22, 2001 02:31 PM
SG1221
Mar 5, 2001 08:47 PM
