What is this that came with my Blaster???
Old Nov 19, 2003 | 03:07 PM
powrtrippin's Avatar
Default What is this that came with my Blaster???
Bought a blaster and in the bag with the owners manual and the spare key is a little brass looking threaded thing with a hole in it. This is my first quad, so take it easy on me, what the h3ll is it?
Old Nov 19, 2003 | 03:09 PM
BLASTERDEVIL2's Avatar
sounds like at jet to me.
Old Nov 19, 2003 | 03:13 PM
Any reason they would send me a spare jet? Is it larger? Am I supposed to use it after the break-in period? I don't get it....
Old Nov 19, 2003 | 03:27 PM
just in case you are at a different elevation then what the factory setup is. after breakin do a plug check and make sure your running right. If your not change the jetting. what size does the new jet say on it. your stock will be a 230. if your running to lean you need to go up a size if your too rich you will need to down a size.
Old Nov 19, 2003 | 03:34 PM
Thanks for the info... Will check that!
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
