Shifting the raptor.
Old 11-20-2003 | 12:14 AM
BigScary's Avatar
Default Shifting the raptor.
the only time I feather is when I run 15/40
you just have the revs right under the limiter..........let the clutch out almost all the way and work it in and out a couple of times
just play with it..........feather as little as you can to keep it from lugging.......
Old 11-20-2003 | 12:29 AM
TJw6981's Avatar
thats what i do but then it launches and dies... my cousin can do it but i cant but i can do it on his baja... think the clutch needs fine tuning?
Travis
Old 11-21-2003 | 12:02 AM
RaptorRider139's Avatar
Dude that sucks its eathier your trans shifting drum (happened to me to). or the shifting lever is too high or low just get a pair of pliers and turn the adjustment hooking the lever to the engine.
Old 11-21-2003 | 12:19 AM
Yamaha660R's Avatar
BigScary...you raced that YFZ????
You win???
  #15
Old 11-21-2003 | 10:42 AM
skullplant's Avatar
Since I replaced the stock linkage style shifter with a Pro Design I have not had that problem.
  #16
Old 11-21-2003 | 11:46 AM
BigScary's Avatar
You win???
no I haven't raced it..........but even he says that I would smoke his @ss...........maybe when he bows up and puts a stroker motor in it.......[img]i/expressions/face-icon-small-happy.gif[/img]
LoL
he has the cam and yz needle ordered..........that may change things a bit!!!
  #17
Old 11-22-2003 | 03:04 PM
ba01raptoraz's Avatar
Take the shifter off and rotate it down one or two notches. That solved my problems.
  #18
Old 11-22-2003 | 03:39 PM
TJw6981's Avatar
so just adjust it to where its firm on my shoe?
Thanks
Travis
95wolv
09-27-2024 12:00 PM
Clint Russell
09-25-2015 03:20 PM
patrick.oc123
09-16-2015 03:45 AM
BigCam
09-16-2015 01:53 AM
patrick.oc123
09-15-2015 02:45 PM
Quick Reply: Shifting the raptor.
