Trouble with Tie Rod Ends
Old Dec 1, 2003 | 06:55 PM
raptorinmexico's Avatar
Default Trouble with Tie Rod Ends
I am trying to tighten the universal joint shaft on my tie rod end to my steering spindle, but when I try to tighten the universal joint shaft to the spindle, it just keeps spinning. I am too afraid to pound on top of my universal joint with something heavy, but there must be an already known technique to get the taper shaft into the spindle and tighten it to torque. Any help would be appreciated.
Old Dec 1, 2003 | 07:00 PM
warrior007's Avatar
I use a c-clamp, kinda clamped offset so you can get to the nut, its not alot of force but enough to hold it and get the taper to do the rest once its a little tighter.
Old Dec 1, 2003 | 09:01 PM
Thanks for the response. It seems that the C-clamp will do the trick, and I will try it once I get my new universals.
RIM
Specta
Family ATVing Photos
Dec 7, 2018 08:22 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
Jaymc
Sep 11, 2015 07:45 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
toonces
Sep 5, 2015 01:14 PM
