making warrior wider
I agree with colby.I just flipped the rears and gained about 3 1/2 inches if I remember right.It made the bike much more stable for racing but it does make it a little harder to turn.I will be flipping the fronts but I didn't want to yet because I can flip the rears back around to keep it narrow for trail riding.Once you change the fronts around you can't change them back easily because of the valve stems.I also got rid of the 22 inch balloons on the back and put on a set of Maxxis razrs 20x11x9.Worked great on the track but it killed the ground clearance and made the ride much firmer for trail riding.The ideal setup would be to get two sets of rims and just swap back and forth.
#15
I agree also with the comments about only widening the back. It makes for tippy turning. I've asked around my local shops for flush valve stems and I'm not able to find any. Another option to that, if you can't find them is to invert the valve stem for the inside, drill a new hole in the other side of the rim for another valve stem. I haven't done this task simply because my quad won't fit in my shed when widened.
I gained about 3-1/2" overall in the back. Not sure what the front offset would be.
#16
#19
i hav a warrior that i race and i fliped my rear rims and front. it make it more wider but wut helps big time i just got an axle from lsr thats +2+2 on each side and i got a set of wicked products a arms taht are +2+1 and its so much nicer now. i hav kenda klaws on it and it slides and does wut u want. u will likenot tip over
1996 Warrior:
F.S.T 450 Big Bore Kit
Yoshimura Full Titanium Exhaust
Stage 2 jets
Works front shock(dual rate w/rezzys)
Wicked Products a arms +2+1
LSR Excalibor axle +2+2
LSR Swingarm +1
Kenda Klaw (front-20*6-10 on itp T-9 Baja Rims)(rears-18*11-8 on ITP T-9 Beadlocks
AC front bumper
AC Skid Plater
AC Nerf Bars
Tag T2 handle bars-Cr High Bend
This warrior rips!!!!!
if ne one could answer my question i would love them?
would a raptor or banshee rear shock fit on a warrior?
and if ne one has a elka/works/pep/axis/etc rear shock they want to sell...contact me!!
1996 Warrior:
Stage 2 jets
LSR Swingarm +1
AC front bumper
AC Skid Plater
AC Nerf Bars
#20
dunno about the banshee
