04 Blaster plastic on a 89?
Old Dec 21, 2003 | 11:21 AM
Dmonik's Avatar
Default 04 Blaster plastic on a 89?
I got a rebuilt 89 Blaster, and I like the look of 04 blasters. Is it possible for me to put the 04 Blaster's fenders on my 89? Will I have to do much converting? Is it easy to move the headlight down to the new location in the fender? Help me out here guys, gimme lots of info.
Old Dec 21, 2003 | 11:41 AM
zbutcher400's Avatar
you should be able to do it, i dont think they have changed the frame in years, you might just have to drill more wholes threw the plastics so you can put the screws in if there in deifferent spots.
Old Dec 22, 2003 | 10:31 AM
Blaster200FMF's Avatar
All the blasters from 88-04 are the same execpt for the brakes and front plastic.
you will need to weld a tab for the front plastic and the front light which is only a slight mod.
Then you will need the front plastic and head light for it , another thing you can add is the new rear tail light , it has a brake light on it and all you would need is the trigger switch that goes from your light to the brake pedal.
I just went through the same thing but addded aftermarket lighting instead of the new head light style.
Hope this helps you.
Old Dec 24, 2003 | 12:25 PM
Dmonik's Avatar
thanks for the help guys. I highly appreciate it
wendal
Aug 3, 2024 10:03 PM
Joe454
Nov 20, 2020 01:19 PM
Ahtatu
Sep 28, 2015 12:14 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
nastyblaster100
Sep 13, 2015 01:19 PM
