big problem
Old Dec 23, 2003 | 06:31 PM
01warrior88's Avatar
Default big problem
i got a yamaha warrior and i went to go and change the swing arm bearings. But once i got the nut off to the linkage bolt i went to go and pull out the linkage bolt and it wouldn't come out. Then i tried turning it thinking it was just rusted in there but i found out that it was bent in there. so what would you guys suggest to do to get it out of there. thanks
Old Dec 23, 2003 | 07:24 PM
RaptorOwner's Avatar
Default big problem
I would get a punch the size of the whole and hammer that thing out. Then go order you a new bolt and nut cuz I wouldnt put the same one back in.
Old Dec 23, 2003 | 07:39 PM
Default big problem
pounded it with a five pound sludge hammer, didn't budge. I dont want to hit it real hard, don't want to bend the frame. You think i could drill it out, hydraulic press what do you guys think.
Old Dec 23, 2003 | 08:06 PM
dragracer789's Avatar
Default big problem
Most of them are tapered.
Old Dec 23, 2003 | 08:35 PM
Default big problem
what do you mean there tapered
Old Dec 23, 2003 | 08:50 PM
zrider182's Avatar
Default big problem
warriors r stupid anyway just sell the POS.
haha j/p mikey [img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 23, 2003 | 09:30 PM
Default big problem
Pritty much it means its never coming out! lol Its a long bolt and on the inside it skinnyer and there is metal all around that part so it WILL NOT slide out or in unless alot of forse is applyed. it will turn but wont slide. I AM not saying the worriors is tapered but it could be. You can get it out. you could drill it, or just pound on it untill she breaks loose liek i did once. Im pritty sure you can buy an aftermarket bolt that isnt tapered, but I AM NOT POSITIVE. You should look into this more and see if they do sell one that isnt tapered and if they do you can distroy that bolt and buy a new one.
looks liek []===----===[] kind of. Picture that only metal.
Old Dec 23, 2003 | 10:22 PM
z400rider28's Avatar
Default big problem
Ran into the same problem before, just had to spray with penetrating oil and keep walin on it with a hammer until it comes out. You will have to buy a new bolt which runs around $30. Might try an air chisel if you got one.
Old Dec 24, 2003 | 02:43 AM
GYTR's Avatar
Default big problem
I would also recommend the air chisel. Them things work wonders.
Old Dec 24, 2003 | 01:04 PM
Default big problem
thanks alot for the help guys, ill try to find an air chisel but i think i might just brill the bolt until it reaches the swingarm then hopefully the swingarm will drop out then ill try to pound out the the rest of the bolt. Well if all else fails ill just take it to the dealership.. Thanks
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
