Warrior carb inf0
Old Dec 22, 2003 | 09:12 PM
Warrior350ripper's Avatar
Default Warrior carb inf0
does anyone think its worth it to buy a carb for a warrior...maybe a bigger one for power? and wheres a good place to buy one[img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 22, 2003 | 09:16 PM
oh yea another thing...istripped the screws on it and can't jet it[img]i/expressions/face-icon-small-confused.gif[/img]
Speedy2222's Avatar
Is A Power Sport Junkie!
the stock 1's pretty good what is it 36-38 mm??? i don't rmember i'm prolyl thinkin of a dif quad tho..
Old Dec 22, 2003 | 09:57 PM
anyone else
Old Dec 22, 2003 | 11:11 PM
95wolv's Avatar
You can get a round slide Mikuni from Alba Performance, about 184 bucks,supposed to flow a lot more than the stock one, for more top end. Then there is the Edelbrock Quicksilver, externally adjustable jetting, supposed to add 3-5 hp by itself, but is spendy, about 430 bucks. To get your stripped screws loose, either use a needle nosed vice grip to grab and turn them, or take a hacksaw blade and put a slot in them and use a flat screw driver to get them loose. Then get some metric Allen head bolts to use in their place, I think they are M4's or M3's. the socket head gives you a lot more grip on the head to turn it.
Old Dec 23, 2003 | 12:21 AM
2003warrior's Avatar
one thing that i do when i jet is to use a pair of small vise grips to loosen the screws on the bowl then screw them out the rest of the way with a screwdriver. the ones i use are not the needle nose ones but the regular tipped ones, the needle nose ones roll off the head to easily IMO
Old Dec 23, 2003 | 12:57 AM
thankx
Old Dec 24, 2003 | 03:51 PM
Eceriderjbomb's Avatar
if everything is stripped its a good idea to get a new one..
my wovy is actin up it weon rev ip could it be bad gass or shoul i clean my carb i dont know what tyo do
Old Dec 24, 2003 | 04:22 PM
JakalWarrior's Avatar
I ran a lectron 36 flatslide on my fully modded 350, it gave it a good bit more than the stocker on top end and it felt like it could have taken more.
Reactant
Mar 30, 2022 02:08 AM
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
Aitch
Jul 21, 2015 09:40 PM
Reactant
Jul 16, 2015 10:29 PM
