Changing sprockets on Raptor
Old Dec 23, 2003 | 11:41 PM
Punker660's Avatar
Default Changing sprockets on Raptor
I would like to change the gearing while I'm at it. Any suggestions of what would be best? What size chain to buy as well w/ new sprockets.
Old Dec 23, 2003 | 11:53 PM
Yamaha660R's Avatar
What are your mod's, and what are you wanting to do....higher gearing....lower gearing....???
Old Dec 23, 2003 | 11:54 PM
Outlawlawndragster's Avatar
Do you want to go fast or slow?
Old Dec 24, 2003 | 12:00 AM
Punker660's Avatar
First things first, I want to go fast. As far as mods go, full exhaust, k@n air filter, jets. I ride mostly mx style, A lot of jumping and hauling. I really don't know what a difference gearing will make that's why I'm asking you guys. Thanks for the prompt response.
Old Dec 24, 2003 | 12:06 AM
Yamaha660R's Avatar
If you ride MX style and want to have great acceleration and lower end then run a 12 on the front, and your stock 40 on the back.
that will give you a 12/40 gearing that will give you alot of low end. you'll lose some speed on top end, but you'll have lot's of low end and that will help you in mx style races or riding.
if you want alittle more speed instead of low end then put a 14 on the front, and that will give you more top end speed.
Old Dec 24, 2003 | 12:15 AM
Punker660's Avatar
Any tips on which brand to buy. I do know not to buy aluminum and spend the money on stainless. Isn't 12/40 the stock gearing? If it isn't what size chain do I need.
Old Dec 24, 2003 | 12:27 AM
Yamaha660R's Avatar
13/40 is stock gearing.
And if you go down to a 12/40 gearing then you should just get the standard chain and you can knock a couple links out when you put it together with the master link.
Old Dec 24, 2003 | 12:53 AM
SpArX's Avatar
I got the stock chain with a 12 tooth countershaft sprocket, no need to knock and links out unless it stretched beyond belief! Just readjust your rear carrier/ chain backlash, you'll have enough adjustments, I'm putting on a 14 tooth for winter riding here soon, see how much on the GPS that'll give me... I need high speed river riding in winter, and I'm never in a gear below 2nd anyhow, it'll make me use more of my gearing... 12 tooth was perfect for summer, mad torque with the 40 tooth rear sprocket, not bad top end, 75MPH dead on the GPS give or take 1MPH on a flat smooth gravel road tapped out for 20-30 secs... Was dead on with a Pred with pipe and filter...
Old Dec 24, 2003 | 01:11 PM
01warrior88's Avatar
hey sparx how much you want for that edge x 700, give me some details like mileage condtiion and what not
Old Dec 25, 2003 | 01:26 AM
SpArX's Avatar
How you supposed to pick up a sled when you live that far away? I'm not really into shipping it, have no way to go about it and all and it seems risky.... It's in awesome shape, 1.25" rear track, sonic blue X package snowchecked, rear Fox clicker shock, 2150 miles, rebuilt under warrenty due to faulty oil pump at 1500miles(air bubble in line), lots of changed out parts(color matching), bar ends, windshield bag, two windshiels, stock and low blue....
Bratman2
Aug 6, 2022 01:42 AM
oldschool64
Aug 12, 2015 07:13 AM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
