warrior trouble
Old Dec 30, 2003 | 04:04 PM
JdBlaster's Avatar
Default warrior trouble
my friend has a 99 warrior and he just got a cobra exhaust pipe and now everytime he starts it up and revs a little it make a loud click and then it stalls. It sounds like it is coming from the carb but he doesn't know if the jetting was done on it. thanx for then help.
88' blaster dg and k&n otherwise stock
83' 250r atc to much to list
Old Dec 30, 2003 | 05:30 PM
Crotts's Avatar
Have him check the plug, sounds like it might be lean to me.
Old Dec 30, 2003 | 05:50 PM
Raptorx44's Avatar
also check for tears in the carb boot going into the head
Old Dec 30, 2003 | 06:01 PM
JakalWarrior's Avatar
Prolly the parking brake, that makes it backfire. Its more of a pop than a click though. Make sure the parking brake is all the way off.
Old Dec 30, 2003 | 08:30 PM
JdBlaster's Avatar
nah its not a backfire its a loud click i know it has somethin to do with the carb or somthing
Old Jan 1, 2004 | 01:52 PM
KDXRyder200's Avatar
My friend has a 1990 Warrior that did that everytime he rode it. I tried to turn the idle screw down but then it would do what you described. It would pop and then it would idle perfect and then it would do it again and stall and he turned the idle up becuz his electric start doesn't work and his pull starter is ripped out. And it is comming from the carb and it is jetted lean. My friends was doing this becuz the carb boot going into the head was cracked. I could see it when it was dark out and it popped i could see the flame shoot back through the carb so tell him to check for cracks in the carb boot and check the plug after you fix the carb boot.
Old Jan 3, 2004 | 08:06 PM
JdBlaster's Avatar
alrighty sounds good thanx alot
blaster
Soon to come yz or cr 125
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Clint Russell
Sep 25, 2015 03:20 PM
Bernhard
Sep 25, 2015 12:45 PM
