Rappy problem
Old Dec 30, 2003 | 05:54 PM
needakfx400's Avatar
Default Rappy problem
Well its about the reverse,when i let off the clutch when its
suppose to pull,it just kinda goes putt putt putt and it will rev
when i pull the clutch back in.....i smell a lil bit of gas only when
i do it in reverse tho....
Old Dec 30, 2003 | 08:39 PM
bighonda's Avatar
mine does the same thing when i am in the sand dunes. the reverse on the pators are not very good. i hope you didnt get it because of the reverse. when you have it it reverse u got to give it more gas.
Old Dec 30, 2003 | 08:44 PM
UBETRUN's Avatar
After 01, Yamaha put a reverse rev limiter in the Raptor. You can't rev it up in reverse by design, there is nothing wrong with your quad. If you want to get rid of the reverse rev limiter, there are a couple of ways to do it. The easiest is to ground the green/white wire under the front sprocket but this keeps your reverse light from working. There are kits that include a switch to bypass the reverse rev limiter but still allow the reverse light to work.
Old Dec 30, 2003 | 09:05 PM
thanks guys
Old Dec 31, 2003 | 06:06 PM
QuadFMX's Avatar
I got a override ,kit including switch, from ebay for like $15 and it works great. Go to raptortranny.com and check out the reverse rev limiter link at the bottom of the page.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
