Getting the GOLD off the Banshee wheels
Guys and Gals,
I know this has been covered before, but I cant locate the thread. ANyhow, What is the best and easiest way to remove the gold paint off of the Banshee/Blaster/Warrior wheels. Thanks in advance...
RoostKing...
RoostKing...
RoostKing,
Removing the gold anodize was one of the first things I did to my Banshee.
Use Easy Off oven cleaner to help disolve the anodized coating. Figure on about 1 can per wheel. You'll still need an abrasive to completely remove it. I used the red Scotch Brite pad to get it all off, then the grey (very fine) Scotch Brite pad. Once you have it fairly slick, get some Mothers Polish or Eagle 1 equivalent and use 00 (super fine) steel wool. After that, you can just polish them up with a soft rag and the Mothers Polish.
Here's a pic of my wheels after I removed the gold color, but you'll have to excuse those old tires! http://www.vci.net/~bash/redhuba.jpg
PS... I've since put new Holeshot XCTs all the way around as well as a Moto-Fast 2-into-1 pipe. Do you think that I can get more than $3,000 out of it? It has about 20 hours on the engine since a complete bore (.020 over) and rebuild job at the local Yamaha shop. I've also put the Toomey idle kit on the carbs and removed the TORS.
badgerboy1
Sep 26, 2017 06:11 PM
Oct 10, 2015 10:20 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
