warrior jetting questions
Depends on your elevation above sea level. For my FMF, they recommend a 155 main. Stock is 145. I'm under 1000' elevation and running stock jetting. The plug is a near perfect dusty brown/tan color. When I get around to doing filter and airbox mods I'll probably purchase a 150 and 155 main jet and see what works best.
Good luck!!
Good luck!!
It really depends on your elevation. I have a supertrapp exhaust, twin air filter and modified air box and I run a 152.5 main at about 5,500 above sea level. The engine runs just slightly on the rich side, but I feel a 150 main is too small. If your removing the stock air box lid, start with a 155 main and go from there (if your at sea level to 3,000 ft).
Good luck
Good luck
