Chain Problem
Old Jan 10, 2004 | 05:13 PM
warrior68man's Avatar
Default Chain Problem
OK....Just put Brand Friggen new chain and sprockets and my beast and the rear sprocket seems like its already mushrooming and its slipping. The chain tensioners are all the way in and the axel is pulled all the way back...I Haven't even been riding it much...it was loose aso I have been adjusting it to make it better and test riding it.....so I doubt it already streched......even if it did...not alot....so I don't know what else to do....I will probably take a link out of it but errr........I just put a brand new friggen one on....and new friggen sprockets.....and a new chain roller cuz it got tore up from before......and new brakes(nothing to do with the chain but just how much ive spent)
Anyone please help.
Old Jan 10, 2004 | 05:26 PM
Eric250EX's Avatar
umm, the sprockets are for a worrior right? well all i can say is take everything off that u put on and then put it on again and dont screw up this time. iff all falls go to your local yomaha dealer
Old Jan 10, 2004 | 05:56 PM
Carnivore's Avatar
There aren't that many choices here. If everything is new like you say, either your sprokets are too small or your chain is too long. For a stock '97 Warrior sprockets are 13 tooth front 40 tooth rear I think and 98 link chain. Old Warriors had 100 links. My guess is your chain is too long. Take out a link and re-ajust. Hope for the best. What kind of chain did you buy? Cheap chain streches like crazy..
Old Jan 10, 2004 | 06:04 PM
I forget what kind of chain it was but I bought a 12th tooth front and 40tooth rear with a 98link chain.
Old Jan 10, 2004 | 11:14 PM
dragracer789's Avatar
Its because you went one down in the front. If it was in the back you wouldnt have even noticed it, but sence its in the front it makes a big diffrence. Take the chain off and take a link out.
Old Jan 11, 2004 | 12:49 AM
Nope....My rear bearings are shot...the axle moves while everythings tight....thanks anyway guys,
Sjrpp
May 2, 2023 03:59 PM
Firefighter400
Oct 8, 2022 06:38 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
