Stroker Kit
Old Jan 16, 2004 | 08:43 AM
Shav0's Avatar
Default Stroker Kit
Can someone explain what exactly a stroker kit is and how it works?
Old Jan 16, 2004 | 08:56 AM
yamamayzf1000r's Avatar
Default Stroker Kit
A stroker kit changes the stroke of the piston/crankshaft. By increasing the stroke (down travel of the piston) you are allowing a higher volume of air/fuel to enter the cumbustion chamber. Visualize this: Your top dead center will stay the same in relation to the cylinder head but on the down stroke your piston will go a few mm's lower in the cylinder than stock.
Old Jan 16, 2004 | 09:22 AM
Shav0's Avatar
Default Stroker Kit
how do they do this?
Old Jan 16, 2004 | 11:19 AM
Default Stroker Kit
They have to machine the crank and move the location of the connecting rod journal. Depending on the engine and how much of an icrease in stroke you want the engine cases may also need some altering. Falicon is one of the more popular and reputable crankshaft companies out there.
Old Jan 16, 2004 | 01:06 PM
Hiram's Avatar
Default Stroker Kit
Read this
YZBlaster250
Nov 15, 2001 11:36 AM
mentalmojave
Nov 3, 2001 11:02 PM
gaff
Oct 23, 2001 05:35 AM
BANSHEE4EVER
Dunes and Dune Machines
Dec 20, 2000 08:56 AM
Zorro
Dec 11, 2000 08:56 PM
