Blaster help
Old Jan 17, 2004 | 11:53 AM
Shav0's Avatar
Default Blaster help
Im hearing alot of different stories about the best filter for the yamaha blaster. my local dealer is saying never to put a K&N on a 2-storke, How does that make sense?? Whats the best thing to do? should i go all out and put in a new air box, or just drill holes in the lid or go with the K&N?? any help would be greatly appreacited.
Old Jan 17, 2004 | 02:44 PM
rede34m5's Avatar
i think k&n is the best. if you run sand dunes you can run the set up where you have the k&n right of the back of the carb for maximum air intakes. make sure to put an outerware over the filter to longen its life. a lot of shee's run the same set up if you've ever seen it! good luck!
Old Jan 17, 2004 | 02:48 PM
Hozed's Avatar
i dont see the problem with a k&n on a 2 stroke... i dont think a foam filter stops as much fine dirt particle... JMO
Old Jan 17, 2004 | 02:57 PM
RaptorRidr660R's Avatar
If you run in dusty areas I would not run a K&N filter, get a good foam filter! I had a K&N once and you could tell that alot more dust was passed through it then a foam filter!
Old Jan 17, 2004 | 10:40 PM
Shav0's Avatar
what about holes in the air box lid? are they a good idea or do they even help at all?
Old Jan 17, 2004 | 11:51 PM
rede34m5's Avatar
i dont think it helps at all just the same no lid.
Old Jan 19, 2004 | 08:35 PM
mojavekid13's Avatar
SUp chad
About time you got on this form
We cant go touring with the old mojave any more, but the CR will be just as fun!Make some even CRAZYer hills! haha
Old Jan 19, 2004 | 08:46 PM
blaster2002004's Avatar
K&N is more expensive its a better than the foam filters out there. If its bad on a 2 stroke why do they make them![img]i/expressions/face-icon-small-confused.gif[/img] Anyway if you want performance go for the K and N but there is a couple of pretty good foam filters out there. Make sure you maintain them by using filter cleaner and you will get your money's worth out of them[img]i/expressions/face-icon-small-wink.gif[/img] HONDA SUCKS! There old, and the smell!
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
