where do you buy the 3 cilender banshee kit?
You can call Twister Crankshafts, A&S Racing, or Trick Racing.
Trick has built a 4 cylinder using stock Banshee cylinders. A&S has a 3 cylinder Banshee with Cheetah cylinders. If you've got the money, they can build it. Last I knew, a triple cylinder Banshee motor built by Twister was around $10,000. At least that was what they said in the mags.
I also saw in the mags, that Twister had a 3 cylinder utilizing the stock Banshee cylinders with a 10 mm stroker crank. And he had a stock stroke 3 cylinder using the stock Banshee cylinders that had a turbo on it.
I'm not trying to imply anything here, but you don't think a 520 or 535 twin isn't enough?! [img]i/expressions/face-icon-small-shocked.gif[/img]
Daren
Daren
Yeah, there is a 3 cylinder banshee that comes out to the track sometimes, but I'm not impressed with it at all. Spend the money on a good T-Rex motor, or if you have it a crankenstein. Stay away from the banshee tripples until they are perfected.
http://bansheeracing.com/triplevtriple.mpg
89mph up olds hill now tell me those triple Banshees arent fast.
07-07-2015 11:00 PM
