What exactly is the function of the speed sensor?
Old Feb 3, 2004 | 11:20 PM
RaptorRacer1's Avatar
Default What exactly is the function of the speed sensor?
Does anyone know for sure what exactly the speed sensor does? Is it necessary? Can you run without it? There is a guy on EBAY selling a block off plate for the speed sensor, check it out.
http://cgi.ebay.com/ebaymotors/ws/eB...category=43981
I would like to get rid of as much of the extra crap as possible for racing and ease of cleaning/maintenance. What will not having the speed sensor do to my engine or CDI?
Thanks!
RR1
Old Feb 3, 2004 | 11:40 PM
warrior007's Avatar
I havent been able to figure this one out either. But I do like the idea of getting rid of it.
Hes a cool guy I talked to him a few times.
Old Feb 4, 2004 | 12:36 AM
sandjunky660's Avatar
i have been trying to find that same thing out for a long time!
Old Feb 4, 2004 | 06:21 PM
UBETRUN's Avatar
Well, I'd imagine you lose your rev limiter. Other than rev limit, I don't think the CDI uses that signal to trigger the spark. If it did, his block off would keep the motor from running.
I'm curious too, why doesn't someone buy one and let us know:-)
Old Feb 4, 2004 | 09:50 PM
I just bought one. I will let you know if it works. I will be using it with a Dyna CDI box, so I will call them first to see if their CDI needs a signal from the Speed Sensor. The dude is charging me $10 for shipping on that tiny little piece that he could have dropped in an envelope and mailed to me for $1. I think he is just trying to make some more money. JMO
RR1
Old Feb 4, 2004 | 09:58 PM
warrior007's Avatar
After thinking about it,
its named speed sensor, so it must be a remnant from the street bike days of the motor.. disconnect it and it doesnt do jack.. maybe they kept it on incase the gov't said they gotta have a speedo? I dunno,, its a piece of junk we dont need is all i know.
SHOTGUN's Avatar
On a kawasaki, the speed sensor is used to control the timing.
the speed sensor looks at the teeth on a gear in the transmission. every tooth that goes by is a pulse, the number or pulses in a minute is the frec. the CDI reads the frec. and adjust the time.
That is why on a p650 or p700, kawasaki uses it to retard the time on bottom and top end to detune the motor.
I think the yammy uses a similar system to detune or at lease as a trigger for the CDI to control the timing.
Old Feb 4, 2004 | 10:19 PM
warrior007's Avatar
yeah but this one is on the output shaft of the tranny. not the crank, cam or clutch basket so that couldnt work
Pehter
Oct 3, 2024 11:00 PM
Jeff Roper
Feb 1, 2022 11:48 AM
ReconBayou
Sep 23, 2015 02:41 PM
Jeff Roper
Sep 21, 2015 02:11 PM
